Anybody know what the redline is for '74, '89, and '96 460's?
Also, I was at a used book store the other day and found an engine manual that covered both 460's and 534's. I may live under a rock, but I'd never heard of this 534. It certainly sounds cool, but I know nothing of it. If someone could tell me anything about the 534, or the redline, that'd be great.
I don't know what the official redline is since I don't the manual handy. But I will say, on my 94 F250, anything above 4,000 is pretty much just thrashing around, ie you are not getting much more out of the engine.
I have read on this digest that approaching 5,000 is a bad idea since the rods are not up to continued high revs.
id find it pretty hard to even get much past 5500 rpm out of a stock fuellie. i think that the 534 was found in some older two ton ford trucks, but im not certain.
Different "stock" Ford engines have different maximum RPMs based on piston
speed:
289 - 7,317 rpm max
302/5.0 - 7,000 rpm
351 - 6,000 rpm
390 - 5,556 rpm
400 - 5,250 rpm
428 - 5,276 rpm
460 - 5,455 rpm
(Some high performance "stock" engines have forged cranks and pistons and
could survive higher RPMs than listed above, use the heavy duty formula for
those engines)
I do not agree with your formula. For one thing most hydraulic cammed engines will float the valves past 6000 RPM...less RPM if the engine has high miles. Also I would guarantee you that a stock 289-302 engine that was regularly spun to 7,000 and above WILL break. Stock rod bolts and cast pistons are over-stressed once you start climbing above 5,000-5500 RPM and like the above post says you'll be way out of your cam power-range and will not be making much horse power anyway.
Your formula is about right for the larger engines from the 351 on up...5,000-5,500 RPM being max. But you will be out of the power range when you spin the engine that high. Deen
