distributor stuck!
Old Mar 6, 2002 | 10:04 PM
dewey_gubbels's Avatar
dewey_gubbels
distributor stuck!
Old Mar 28, 2002 | 10:27 AM
rics91's Avatar
rics91
Post distributor stuck!
after loosening my distributor hold down clamp and using a wire brush and penetrating oil to remove the rust around the base of the distr. shaft, i still cant budge the darned thing. i'm trying to adjust my timing. suggestions? TIA.
ric
91 f250s/c 7.5L w/89k miles
Old Mar 28, 2002 | 01:52 PM
Mil1ion's Avatar
Mil1ion
distributor stuck!
There seems to be a lot of this.
Just keep spraying the penetrating fluid to it and keep trying it.
Sometimes pouring some Coca-Cola(tm) on it helps too.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
[i][font color=red]Calgary,Alberta,Canada[/font][i]
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=3180&.jpg
http://community.webshots.com/user/mil1ion
[font color=green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Old Mar 28, 2002 | 02:43 PM
rics91's Avatar
rics91
distributor stuck!
>Dennis
LOL! i'm a pepsi guy ;-)
ric
91 F250 S/C 7.5L w/Banks Power Pak
Old Mar 28, 2002 | 08:12 PM
shortbedford's Avatar
shortbedford
distributor stuck!
hey rics if those ideas dont work, remove the vacum advance and using a oil filter wrench to rotate thst dist use carb cleaner spraying around the bottom of the shaft. Hope that helps good luck, chuck.
Old Mar 28, 2002 | 09:42 PM
Mil1ion's Avatar
Mil1ion
distributor stuck!
>>Dennis
LQ
That's probably why you are suffering from Seizures !
Old Mar 29, 2002 | 12:31 AM
the law's Avatar
the law
distributor stuck!
This happened to both of my 460's, '74 and '89. I tried the penetrating oil on both for a few days and it didn't work with either. Now I am known for lapses in judgement when I'm mad at a mechanical object, and I get pretty firmly into the belief that if it's gonna be fixed, the proccess is gonna showcase a crowbar somewhere along the line. For both I just wedged a crowbar between the block and the distributor housing and gave the bar a good yank. I went fairly easy on my '89, but with the '74, since it was already toast, I gave it everything I had. It worked with both and it's kind of a last ditch option, you just gotta make sure you don't mess up or crack your distributor housing.
The Law
Old Apr 1, 2002 | 05:02 PM
79F2504x4's Avatar
79F2504x4
distributor stuck!
Try taping on it with a hammer working it back and forth, thats what I did with mine and it worked great.
Chase
1979 F-250 4x4
71 460 Holley650, MSD OFFROAD, L&L Headers
C6-B&M Transpack
Dana HD44Front/60Rear
35 inch Goodyear Implement Tires
4 inch Skyjacker System
Much more to come
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
