Old Mar 8, 2002 | 10:44 PM
LxMan1's Avatar
LxMan1
77 460
I've got a 77 f-150 w/ 460 C6/ 3.00 9".
It has an Edelbrock performer manifold, 750 carb and double roller chain, CompCams 268H, lifters and valve springs, with Dynomax headers, 2 1/4" pipes with mustang flowmasters.
Anyway, My question is, what is the actual bore and stroke of the 460? The Chiltons and Haynes manuals are wrong because they only come up to about 422ci. They also say that the 460 has a shorter stroke that the 400ci.
Thanks, Jimmy
Old Mar 8, 2002 | 11:22 PM
Ford79's Avatar
Ford79
77 460
460 bore is 4.36" and stroke is 3.85"
Old Mar 8, 2002 | 11:53 PM
LxMan1's Avatar
LxMan1
77 460
That only comes up to 421.66 CI.
The formula is Bore x Stroke x # of cyl. x 3.14 = CI
4.36 x 3.85 x 8 x 3.14 = 421.66 or 422
4.00 x 3.00 x 8 x 3.14 = 301.44 or 302
4.00 x 3.50 x 8 x 3.14 = 351.68 or 351
4.00 x 4.00 x 8 x 3.14 = 401.92 or 400
They are all close except for the 460. Those are the same dimensions that I had.
Jimmy
Old Mar 9, 2002 | 12:42 AM
Superdave's Avatar
Superdave
77 460
Here is a formula I have and it works out.
0.7853982 x bore x bore x stroke x cylinders = CID
Which comes out to 459.84723 rounded off = 460.
Old Mar 9, 2002 | 01:01 AM
LxMan1's Avatar
LxMan1
77 460
Thanx, That works!!
Old Mar 9, 2002 | 05:41 PM
Superdave's Avatar
Superdave
77 460
I cut that out of a Hot Rod magazine eons ago and kept it.
Old Mar 9, 2002 | 07:53 PM
LxMan1's Avatar
LxMan1
77 460
I'm glad you saved it.
Thanks again,
Jimmy
Old Mar 11, 2002 | 08:07 AM
dre's Avatar
dre
77 460
here is a good site.
http://www.smokemup.com/utilities/calc/displacement.cfm
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,373:1 - 9" Posi.
Old Mar 11, 2002 | 01:42 PM
85351ho's Avatar
85351ho
77 460
just to add something, the 400 does have a slightly longer stroke than the 460, i forget the #......
Old Mar 11, 2002 | 06:04 PM
LxMan1's Avatar
LxMan1
77 460
The 400 has a 4" bore and a 4" stroke.
Old May 6, 2002 | 03:03 AM
trinogt's Avatar
trinogt
77 460
The formula mathematically is pi X radius squared X height X number of cylinders.
This equates to 3.14 X (half bore size)squared X stroke X 8.
You get the same number as the formula. It is a volume formula of a cylinder.
Mark
Ford started it; Ford will finish it!
Old May 7, 2002 | 01:21 AM
Superdave's Avatar
Superdave
77 460
[updated:LAST EDITED ON 07-May-02 AT 02:23 AM (EST)]Huh ????? :-) Just kidding.
Old May 7, 2002 | 08:52 PM
79F2504x4's Avatar
79F2504x4
77 460
Krazy351w
18
Mar 20, 2017 12:09 AM
Mechanix185E
18
May 6, 2011 01:34 PM
i1dery
18
Feb 4, 2006 03:15 PM
pinkhorse
Jul 1, 2004 08:56 AM
tbolt 460
Nov 17, 2001 06:00 PM
