Old Log to New Split Manifold?
Old Oct 30, 2000 | 10:18 PM
dartol's Avatar
dartol
I have an '83 F-100 300 I-6 with the old log style manifold. Can I replace it with the newer split style without major modifications?
Thanks!
Darren
Old Oct 30, 2000 | 10:26 PM
hotrodford_88's Avatar
hotrodford_88
I don't see why you couldn't use it. I would say also get the cats as well, and then see if a muffler shop will put of a high flow convertor for you. You'll notice some more power from the high flow convertor.
1988 F-150 Custom to XLT Lariat conversion, 5.0 EFI (formerly 300 I6), 5-speed M5OD, 3.08 rear gears (will be upgraded to 3.55's), Summit headers, Flowmaster muffler W/ dual 3.5" tips 24" long.
Pioneer CD, AC, Tilt, Cruise, Mobile Radio, Lightbar (Force 4 LP6000), Federal Signal PA300 Siren W/100W Siren Speaker. Caution Customizing in progress, Watch for flying tools & Parts!
Old Oct 31, 2000 | 08:17 AM
TallPaul's Avatar
TallPaul
Dartol:
I'd like to know, when you get your split manifold, what is the inside diameter. Also the inside diameter of the old log manifold. I was told by someone at Clifford Performance that the manifold (even the split) is plugged up with only something like 1/2-inch inside diameter. Even so, the split should perform better than the log--that's why Ford switched to it, but maybe you would want to take it in to a shop and have it opened up a bit and polished for better flow? Regardless, the manifold is only about one foot of the exhaust system and with larger piping after it the performance should be much better.
Old Nov 2, 2000 | 04:42 PM
paulg's Avatar
paulg
Rusty_Old_F250
39
Jan 21, 2018 09:26 PM
bigcrunch
Large Truck
May 23, 2016 08:18 AM
fatheroftwo
Feb 14, 2016 12:46 PM
Oregon86_F250
Mar 6, 2006 05:04 PM
William
Exhaust Systems
Jan 15, 2003 06:53 PM
