You want your readings to be within 75% of eachother. The actual amount of cranking pressure only matters if is is really low. A 12:1 race engine may have less cranking pressure than a 9:1 truck engine.
That should be 10-15 Percent. Take your highest reading and multiply by .15 then subtract the result from the highest reading.
Ex. 150psi x .15 =22.5 150-22.5 = 127.5 So if your highest reading is 150 then none of your other readings should be below 127.5
These readings look pretty good to me.
My engine has a year and a half on the rebuild.
It has been smoking some recently. Mostly black smoke with a tinge of blue. When I smogged it the guy told me it was a little rich. This week I found a vacumm leak at the tree at the rear of the intake manafold. also I had the pcv hooked up to that instead of the port on front of my edelbrock carb.
I changed out the tree and rerouted the pcv and have a great improvment in the smoke. Also I had been pinging a fair amount as well. That cleared up too.
The engine has been a hog on oil consumption, as much as a quart every week and a half, I'm trying to address that as well. It looks like the lower end is okay, so now I'll be looking into other areas. Also I'm suffering from low oil preasure, I don't know if the oil mods were done to my block, when I had the engine done it was before I had read about them here on the site.
Any comments or ideas are gladly accepted.
Thanks,
Hawkeye
