noisy fuel pump
Old Aug 25, 2003 | 05:54 PM
71_4x4_390's Avatar
71_4x4_390
noisy fuel pump
Hello all, I've been away, and still am, on deployment to far and exotic places fighting the war on everything for the USNavy. Before I left home I was going to remove and inspect my fuel pump which has been kind of noisy since the rebuild. It very well may have made this noise before but it wasn't noticed due to the exhaust leaks and generally poor running of the engine. I have a generally cyclic noise from the eccentric cam and fuel pump arm. Before I pull off the fuel pump and fan blade etc. Have anyone else heard this kind of noise, and should I be worried? It pumps fine...
Old Aug 26, 2003 | 05:40 AM
macguyver's Avatar
macguyver
noisy fuel pump
There's a return spring in the fuel pump that keeps the lever in contact with the eccentric. When this spring gets weak (or goes away completely) the lever slaps against the eccentric. That's the noise you're hearing. It'll keep pumping until it finally goes out but it will probably fail sooner than later due to the shock of the sudden hit against the eccentric.
Jgostrenga49855
Feb 7, 2013 06:36 AM
Florida Native 72
Dec 17, 2011 09:42 AM
haroldrussi
24
Jun 2, 2011 01:58 PM
tandpr
May 31, 2009 09:12 PM
knuckle dragger
Aug 29, 2005 07:31 PM
