Injection Pump
Old Jan 17, 2004 | 03:54 AM
otter712's Avatar
otter712
Question Injection Pump
Will an injection pump from a 83-92.5 7.3 fit on a 93 7.3? The for part number is E3 DB2831- 5030. Thanks in advance for the advice.
Old Jan 17, 2004 | 08:14 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Sure, does the 93 have a turbo?
Also the
83 - 87 had 6.9 as the only option.
88 - 94 7.3 IDI
93 - 94 7.3 IDI turbo
Still the only difference is the fuel setting in the pump which is adjustable for any of the above motors.
Old Jan 17, 2004 | 10:45 AM
BSmitty's Avatar
BSmitty
Dave's right, I believe it's the same basic pump design all the way back to the start of the 6.9 as well. I know the basic mechanical aspect of the pump is the same. But untill direct injection on the Power Strokes, the 7.3's should all be the same basic pump.
Old Jan 17, 2004 | 09:15 PM
pnose's Avatar
pnose
Yes it will fit.Is it the correct pump,no.92.5 is what ford called the performance and emissions engine and it used a different pump model along with a different injector code.They are interchangeable but performance and fuel economy will suffer.Now,if you can get the injectors to match that pump you should be good to go.
Old Jan 18, 2004 | 12:42 AM
otter712's Avatar
otter712
Ok, now that that is solved...thank you all. What is a good price to pay for a rebuilt unit like this? I have heard anywhere from $500.00 to as much as $1200.00. That seem to be a pretty big price gap. Thank you in advance.
Old Jan 18, 2004 | 10:38 AM
Dave Sponaugle
Check these guys
http://www.usdieselparts.com/pages.c...0Pumps&code=60
$357.00
