- 96 Explorer 5.0?
- 1992 SUPERCAB 4X4 5.0 5 spd UPGRADES
- main bearing clearances(351w)
- What years to get 351W roller block?
- timing chain question
- 302 diagram help
- lookin for a cam for my 331
- engine pin/ knock/ bang noise??
- fuel pump?
- Flywheel/Starter Problems
- sb starter
- Damaged Timing Cover From Fuel Pump Cam
- 289 Rebuild
- Distributor
- 302 Carb and Intake Problem
- Resetting battery for idle speed changes on Speed density!
- Fuel Milage
- looking into getting some heads for my van need advice
- main bearing torque
- 02 sensor testing...
- switching fuel injected to carbs
- Rear Main seal?
- 302
- 351w belts
- Balancer interchangability?
- what's the difference between 302 in different years?
- Engine electrical?
- Idle surge issue on fresh new GT40 302 motor?
- 302 Motor help
- alternator choices for EFI 302/351
