- C6 bolted to 390. need shift kit????
- Milleage
- intake problem
- She's getting hotter...
- "New" piston option for FE 360
- Any RPM vs. S-Code intake dyno numbers?
- A/C compressor mounting
- Is this worth the trouble...
- camshaft selection
- camshaft upgrade question on intall
- engine specs or id ?
- Fuel-injected FE, can it be done?
- head work pics posted
- Build a 390
- 352 or 390?
- How to do a compression test without a starter or tranny attached?
- Oil Leak
- Two Different heads on rebuilt 390.
- 511 initial timing, incredible!
- can i doubble up on exhaust manifold gaskets?
- Tired 390
- engine colour 361 ?
- Are these compression readings normal?
- Help With 1974 f250
- FE 396 Powered burnout with 46" Baja Claws
- Deieling then backfire through Exaust
- Motor not running
- Flat tappet cam break-in article from Comp Cams
- '68 highboy questions...
- Possible swap to a 300 I6
