Flat tappet cam break-in article from Comp Cams
I just found an article about cam break-in on the Comp Cams website. Good reading. I suggest you all go read it!
http://www.compcams.com/Community/Ar...ID=-1578676008
Also, I found some more FE cams listed! Scroll to the bottom and look at the "specialty cams."
http://www.compcams.com/technical/Ca...95_231-232.pdf
Pretty interesting article. The lifter bore grooving tool is interesting. I've also been mulling over some different lifters possibly. Break in springs also a very good idea. I've never tried the dry silicone spray before assy lube thing tho. I really wanted to try a roller cam but I'm a little learly with a solid lifter block. I have a nice solid Crower stick to use but just their std solid lifters. This is a very timely subject for me and I've been waffeling over the roller cam.
G.
G.
craigibc
01-26-2022 08:40 PM
bruno2
44
10-17-2015 09:02 PM
jonezzzman
06-25-2014 12:08 AM
Brian Uhlenhake
6.7L Power Stroke Diesel
01-29-2011 08:27 AM
