Any RPM vs. S-Code intake dyno numbers?
Well im finally used to the power that the S-Code intake gave me and as usual, I want more. Has anybody actually dyno'd their engines before an RPM intake swap and then after. I have access to a dyno just about anytime I need it, but wanted to know if anybody has done any real life comparisons from the old-school to the new-school intakes.
The big "S" intake is just a plain jane old car 4v intake right? Nothing special. Every FE I've seen from 66 up that's 4V and not a CJ has that intake. I've got a pile of them and scrapped a dozen of them. Is there something I'm missing here? It's a good intake manifold, but not something I'd put on an engine if I was truly concerned over making alot of power or anything above 5000 atleast.
What is an "S" code 390 then? Is that a 390 GT? I was under the impression a 390 GT used the exact same intake as everything else. As iron 4V intakes go, I've seen a ton of the "S" intakes which seam to be the same performance as a performer intake and I've seen the iron cobra jet intakes which are about an inch taller and look like a performer rpm and weigh about 20 pounds more than any other FE iron intake. I see the term "S code" used a lot to describe a 390 with a 4V intake that has the "S" on the intake. Can anybody clarify this for me? Thanks
The "S" code 390 refers to the GT 390 which came in the 66-69 Stangs and Fairlanes. It seems some are confusing the "S" casting 4 bbl iron intake with this engine. While it may be the one used on them originally, it's not a part that contributed to the higher hp rating. As others have said, it was used on the other "std" 390's as well. The parts that set the GT 390 apart in the higher hp rating was the camshaft, the dual bolt patterned exhaust side of the heads (to fit the engine between the shock towers), and the 600 cfm Holley carb, plus the slightly better flowing exhaust manifolds and dual exhuast. Block, crank, rods, and pistons and in the 68-69's the heads are the same castings the same as others of like years. My 68 Merc's high compression 390-2bbl motor is basically the same engine as a GT 390, just missing the GT cam, 4 bbl carb & intake and had the flat-log manifolds.
Originally Posted by averagef250
Thanks. So "S" code is just a grossly over used term for a 390 GT. An FE that wasn't really anything spectacular anyway.
