Milleage
Old May 4, 2006 | 11:47 AM
Snowking's Avatar
Snowking
Milleage
No one believes me that I keep hitting 20 plus with keeping the power up in my 1975. Is it just me. The motor getting 20 is a 360 C6.
Also I just bought a 352 in a 1967 4 spd. I am very pleased with my 360, is there that much of a power/ fuel consumption between the two motors.
Old May 4, 2006 | 02:15 PM
FalconStng's Avatar
FalconStng
20 plus mpg? If that's what you mean then I'd say that's stretching it for a 360. Are you sure of your odometer? If your speedometer/odometer is off then possibly you're registering more miles than you actually drive.
Tracy
Old May 4, 2006 | 03:29 PM
jor's Avatar
jor
You're right, snowking, I don't believe you.
jor
Old May 4, 2006 | 04:24 PM
Six Niner's Avatar
Six Niner
wow i'd be happy if mine got 15. have you changed out the rear gears or changed the rear tire size? 20+ out of an fe sounds like something out of the twilight zone.
Old May 4, 2006 | 05:36 PM
scamardo's Avatar
scamardo
I got 16.9 on the highway once and was tickled pink.
Old May 4, 2006 | 05:46 PM
rusty70f100's Avatar
rusty70f100
Sounds like your speedometer / odometer is way out of calibration. Go find somewhere you can go 60mph and make sure 1 mile takes exactly 1 minute.
Old May 4, 2006 | 09:54 PM
jd_sylvia's Avatar
jd_sylvia
I average 16 out of my 352, the best I ever got was with every condition right flat ground nothing over 65 and no pony starts for a wow factor of 18 mpg. So if you are getting 20 you had better log everything you have done to it and keep it there. Don't try and tune anything.
jd
Old May 5, 2006 | 10:18 AM
Snowking's Avatar
Snowking
I thought I was getting 20 but maybe not, The driveline i haven't touch but when looking at the axle code in my NPD catalogue I got a rearend the gears around 3 flat, a 3.02 I believe is what they called it. Again though I haven't checked anything about my speedometer/ odometer calibration.
Old May 5, 2006 | 10:28 AM
Snowking's Avatar
Snowking
I feel stupid I now noticed everyone who answered is an American answering in imperial gallons. In Canada a metric gallon is quite noticably larger then an American imperial gallon.
Old May 5, 2006 | 11:47 AM
66beater's Avatar
66beater
And now we know. 1 US Gallon = 0.83267 Canadian (Imperial) Gallon. So 20 mpg Canadian is about 16 MPG U.S. Still impresive for a C6, but reasonable.
As for the 352 VS 360, if you bore a 352 .050 over, you have a 360. there is basicly no diffrence between them other than the size of the bore. They share the same crank. There might be a 3 or 4 horsepower diffrence, but there is usualy a 3 or 4 horsepower diffrence between 2 identacle new engines, so you'll never notice it
Old May 5, 2006 | 11:49 PM
Rubiranch's Avatar
Rubiranch
Years ago I had a 1963 Mercury Moterey Custom 2-dr. It had a stock 300 HP 390, 4V carb, 11:1 compression and dual exhaust, and 3.00 gears and only about 60k miles on the car.
On a trip from Denver to Omaha I had a tank of 92 octane and had added 5 gallons of 108 (close) aviation fuel. I cruised as close to 80 as I could. That first tank with the 5 gallons av-gas I got 19.6 mpg. From that point on without the av-gas I still average over 18 mpg on the freeway. Normal around town was closer to 12 and 16 was average on the highway.
Old May 8, 2006 | 09:42 AM
Snowking's Avatar
Snowking
So, there are no really big power differences between a stock 352 and a stock 360.
Old May 8, 2006 | 10:17 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Depends on which 360 - what was it, 1972? They retarded the cam (or advanced, don't remember) to meet emissions and it really dogged the motor.
Something like 12 degrees off...
Pre-72 timing sets have the "correct" timing.
But pre-'72, I'd imagine a 360 and a 352 being basically the same, given the same cam.
Old May 8, 2006 | 10:36 AM
Snowking's Avatar
Snowking
The 360 is from a 75 F100 .
Old May 8, 2006 | 10:55 AM
krewat's Avatar
krewat
That is "supposedly" one of the hobbled 360's if it's still got the stock timing gears.
Anyone else care to comment (please) on the cam-timing situation with 360's?
