Build a 390
Old May 1, 2006 | 07:18 PM
fireater's Avatar
fireater
Build a 390
I am building a 390 for my '79 F150
forged pistons (flat top)
edelbrock heads and intake
Harland sharp rockers
crane extreme energy cam
I want to do Mpfi with holley commander 950 system
gonna deck and line hone block etc
But i noticed .... my Con rods all seem to be same casting numbers but they all slightly look different. For example the nub the sticks up abouve the wrist pin end can vary in height by over 1/8 inch. Should i look for Better rods?
Old May 1, 2006 | 11:02 PM
rusty70f100's Avatar
rusty70f100
I would guess that someone has done a balance job on this motor before. It should be fine as long as you get it balanced.
Old May 2, 2006 | 09:36 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yeah, Rusty is right, sounds like it was already balanced once. Get the rotating assembly balanced this time and everything should be fine.
I'd put on a regular carb first and get the cam broken in and everything before trying to get the MPFI working. Someone else here has already done it, but had a hard time getting it perfect.
Old May 2, 2006 | 01:57 PM
fireater's Avatar
fireater
only one problem we have owned this motor since it was new and it wasnt balanced....
Old May 2, 2006 | 02:22 PM
krewat's Avatar
krewat
I have no idea if the factory tried to match the rods to the pistons, but anything is possible. Was it EVER rebuilt before?
Either way, get it balanced this time around and don't worry about the rods, they'll be matched to the pistons.
Do all the con rods have numbers punched into the big end on both the rod itself and the cap?
Old May 3, 2006 | 09:08 AM
fireater's Avatar
fireater
well i numbered them when i took it apart....
Old May 3, 2006 | 09:09 AM
fireater's Avatar
fireater
Krewat ....do you know who has the commander 950 setup?
