Oil Leak
Old May 1, 2006 | 05:42 PM
bluesky636's Avatar
bluesky636
Oil Leak
My remanufactured 390 has developed a small but persistent oil leak. It is dripping off the back of the engine, sometimes from the bell housing inspection cover, sometimes from the rear oil pan rail. I have pulled the bellhousing inspection cover and it is bone dry around the clutch and inside the bellhousing, so I hope that rules out a rear main seal or oil galley plug (I know that there is a plate between the engine and bellhousing, but I would think any leak back there would find its way into the bell housing. It did in my old engine, the inspection cover was half filled with oil!). I can see oil around the back edge of the oil pan, but cannot find a source. Oil pan bolts are tight. Pan is a stock Milodon with a Ford Racing windage tray, cork gaskets between everything and silicone sealant.
Any ideas as to where to look for the source? Thanks.
Old May 1, 2006 | 05:55 PM
65'f1004x4conver's Avatar
65'f1004x4conver
could be the back of the intake manifold.mine leaks there and i thought it was the oil pan or rear main for a while. just an idea
Old May 1, 2006 | 06:05 PM
fireater's Avatar
fireater
normally intake manifold .... these are notorious for leaks
Old May 1, 2006 | 07:21 PM
bluesky636's Avatar
bluesky636
I've checked both the valve covers and back of intake but will definitely do it again. If it were the rear main seal or oil galley/cam plugs, there WOULD be oil inside the bell housing, right? Mine is dry as a bone in there.
Old May 1, 2006 | 07:29 PM
fireater's Avatar
fireater
yes if the inside of bell housing is dry then it has to be valve cover or intake
Old May 1, 2006 | 07:38 PM
65'f1004x4conver
yeah my money is on the intake. there are lots of threads here about tricks to get those to seal properly, might look them up(i know i need to)
Old May 1, 2006 | 10:41 PM
bluesky636's Avatar
bluesky636
Thanks
I will definitely check the intake and valve covers more carefully this week. I can deal with those a lot easier than something from the back side of the engine.
Old May 3, 2006 | 11:40 PM
customcab66's Avatar
customcab66
My money would also be on the intake manifold every fe ford we have around our place they all leak in the same place, both ends of the intakes.
Old May 4, 2006 | 09:00 AM
bluesky636's Avatar
bluesky636
Rechecked Intake
I rechecked both the valve covers and intake last night. Bone dry. So where I am at is:
1. Inside of bell housing - bone dry
2. Valve covers - bone dry
3. Intake manifold - bone dry
4. Front timing cover - bone dry
5. Crankshaft snout - bone dry
6. Oil filter adapter - bone dry
What's left?
I appear to have a bit of oil around the back edge of the oil pan and gasket. I will probably crawl under the car tonight and look at that again. The oil pan has a Ford Racing windage tray, Felpro gaskets between everything with sealant. The first oil pan (cheap chrome) that was installed would never seal. This one is a gold anodized Milodon pan.
Any suggestions on how to verify that it indeed is the pan? Any way to fix it short of pulling the pan (again) and trying to reseal it? Or should I just live with it as one of those little "FE things?"
I always check the oil level before taking her out. So far there has not been a noticeable decrease in oil level.
Old May 4, 2006 | 09:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The rear main bearing cap has these rubber inserts that go on the side of the cap. If one of these inserts were leaking, it would be right there on the pan... It probably would not get into the bellhousing.
When installing the pan, I put RTV on the ends of the rubber inserts. Sorry, hard to describe and I just cut my finger with a razor knife so it's hard to type
Old May 4, 2006 | 11:49 AM
bluesky636's Avatar
bluesky636
OK. I found some photos on line that show the rubber inserts.
Questions: Would the leak be coming from the ENDs of the inserts (near the block/oil pan interface) or somewhere else? IF the pan is sealed properly to the block, how would the oil work its way out?
Thanks.
Old May 4, 2006 | 12:38 PM
krewat's Avatar
krewat
If those rubber inserts were pushed in too far, and not RTV'd, the seam between the main bearing cap and the block will allow oil to seep out right at the pan gasket.
At least, that's if I'm picturing it right in my mind...
Old May 4, 2006 | 12:48 PM
bluesky636's Avatar
bluesky636
OK. Thanks. I'll take a closer look at it this week. Is there an easy fix?
Old May 4, 2006 | 12:58 PM
krewat's Avatar
krewat
Let some others comment on this first... guys?
