- 6.9 dies at lower idle
- Glow Plug Wires
- Well my brother bought an IDI
- Tire Pressure and do I need to change my oil?
- vacuume pump
- F350 4WD Straight front axle swap into '88 F250 4WD
- fuel leaking
- Installing 6.9L stock tach.
- 6.9 engine will not die when key turned off
- Clutch Chatter
- '88 7.3 auction in No CA
- F350 7.3 idi oil question
- If i took the fuel/water separator off do i have to fill it with diesel likethe fufil
- Rear Fuel Tank Issue
- Fuel pump block off plate install 89 7.3l
- Fan clutch removal? Do I dare?
- sweet deal
- looking at a 94 F-250 Turbo Diesel
- 6.9 diesel faq ?
- ATS outlet housing and downpipe
- Dual tanks
- Fuel Pick-up Problem
- Here we go again!
- TPS ohms???
- Fuel tank removal
- Paint
- Exhaust smoke
- Exhaust on a 7.3Turbo
- '91 Front Calipers & Pads
- replaced tach sensor
