Gearing
Old Nov 1, 2021 | 05:24 PM
Josh Coleman's Avatar
Josh Coleman
Gearing
I'm sure this topic has been discussed at length but I wasn't able to find what I was looking for.
What I'm trying to fix is the truck seeming gutless. I know these trucks aren't the quickest but it can't get out of its own way empty. It was my father in laws truck and I'm playing catch up on some things.
The truck's bio is it's a 92 F350 with the 7.3 IDI and about 290,000 miles on it. A rebuilt E4OD transmission and stock axles I believe it's a 10.25 rear and Dana 60 front wit stock 4:10 gears. I've upgraded to an electric fuel pump, a gear reduction starter from DB electrical and SD front suspension which gave me enough lift to run military 37's.
This truck really isn't a daily driver but when driven does see speed up to 70 mph. So my question how much improvement could I expect with going to a 4:56 gear and would 4:88 be to much? I have no intention of adding a turbo or any other power mods. The truck just seems like it needs to be geared down but I have no experience with making those sort of changes.
Old Nov 3, 2021 | 03:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
4:56 or 4:88 gears will make 70mph your top speed bouncing on the rev limiter.
i have 4:10 gears with 37 inch tires and a C6 trans. and it is all i can do to hit 70 going downhill.
Old Nov 3, 2021 | 09:31 AM
Josh Coleman
I think 4:88's will be too much but the 4:56's will give me the bottom end I'm hoping for. I'm sure the injection pump is contributing to the lack of power. I know these trucks aren't powerhouses but mine seems excessively under powered.
Old Nov 3, 2021 | 06:52 PM
4drocket's Avatar
4drocket
torque vs horsepower
these are built for torque
i doubt that changing gearing will increase get up and go but it will increase the noise
Old Nov 3, 2021 | 07:12 PM
Josh Coleman
I do plan on replacing the injection pump before the gears if that gets the performance where I'm happy with it I'll leave the gears alone. But since I decided I'm going to just restore the truck, I'm trying to plan one step ahead of where I'm at. The transmission is done, the electrical as far as batteries and starter are done. Injection pump, injectors and fuel lines are next. After that I'm going to the axles replacing bearings, seals, brakes etc... figured since I'll be in there now is the time to start learning about pros and cons to choice in gear ratios.
Old Nov 3, 2021 | 07:54 PM
00t444e's Avatar
00t444e
Where did you come up with that info? The OP has an E40D transmission with a .71 overdrive, with 37 inch tires that puts him at about 2100 RPM at 70 mph with 4.56 gears and 2250 RPM with 4.88 gears, either way not even close to the rev limit.
Old Nov 4, 2021 | 04:42 AM
tjc transport
i ain't rite
real life. with overdrive the same truck had a top speed of around 85 mph.
without overdrive it tops out around 70.
raising gear ratio will be about the same as removing overdrive.
Old Nov 6, 2021 | 11:01 PM
FGrinder's Avatar
FGrinder
I have 37 A/T with 4:10 and the ZF5 and get up to 80+ pretty easy even on a 2% without going too high in revs. I try to keep it under 3k though
I can do slightly better in my DRW because better aero and the tires
Old Nov 8, 2021 | 12:06 AM
ihateminimumwage's Avatar
ihateminimumwage
I wouldn't go over 4.10s. Look at freshening the fuel system up and down the line a turbo if you want to wake it up. Ever had the timing set correctly? Good IP, injectors and timing and a NA with 4.10s and 37s will get up and go.
Old Nov 8, 2021 | 04:23 AM
tjc transport
i ain't rite
and that is with a ZF-5.
i said with a C-6 trans it is hard to see 70. .
and i also said with the ZF-5 the same truck would do 85
Cowboy96
Feb 18, 2016 01:34 PM
Nevergetstuck
13
Feb 25, 2013 09:08 PM
Hellonwheels
Apr 9, 2008 05:13 PM
kevbits
41
Feb 16, 2008 01:08 AM
jims406rs
1978 - 1996 Big Bronco
23
Mar 19, 2004 02:07 PM
