Cracked Frame
Old Nov 9, 2021 | 04:50 PM
Wheeler.M1's Avatar
Wheeler.M1
Cracked Frame
I am so pissed. Sorry. I am pissed.
​​​​​​Was cleaning all the grime off my 7.3 idi I purchased not too long ago. Under the muck I found a crack in the chassis behind the front left tire. It was covered in grime and had 33s on so impossible for me to have seen when I purchased it.
​​​​​​What are yalls thoughts? Can a weld fix this? Is it alright if I keep driving with this crack? Man I spent 5k on this truck. I dont believe the previous owner new..
Last edited by Wheeler.M1; Nov 10, 2021 at 09:51 AM. Reason: It's not the Chassis but the Frame, wrong verbage
Old Nov 10, 2021 | 06:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
clean it real good, weld it, and fish plate it.
Old Nov 10, 2021 | 09:17 AM
Wheeler.M1's Avatar
Wheeler.M1
Was told a tungsten insert gas weld is my best bet. Would adding a cross member to connect both sides of the frame help to prevent flexing? After a weld, would it ever be able to go off-roading, or is it just a highway truck now?
Old Nov 10, 2021 | 11:03 AM
Beechkid's Avatar
Beechkid
Drill a small hole at each end of the crack, weld it up, then weld a diamond shape plate over it.... you should be fine! IMHO, I would check to make sure this is not non-weldable material... it's been a few years ago now but at one point Ford, GM, etc. all used frame material that could not be welded.....ie you could weld the crack up but later on the entire member would fail.
As far a welding method goes.... IMHO, doesn't matter as long as you are a competent welder.
FYI...if you are using an "electric welder" definitely DC the battery and remove the ECM
Old Nov 11, 2021 | 04:33 AM
Dieselamour's Avatar
Dieselamour
I would not drive it until it is repaired properly, if possible. I think your liability will now significantly increase if you end up in an accident.
Old Nov 12, 2021 | 12:32 PM
Charmalu's Avatar
Charmalu
Here is a thread I saved on cracked frame, might be of help.
https://www.ford-trucks.com/forums/1...ering-box.html
Charlie
Old Nov 12, 2021 | 04:41 PM
Wheeler.M1's Avatar
Wheeler.M1
Charlie
Very nice, thanks! Shame that he's not active and selling those backets. Going to look into fabbing one. This is on my f250 which has a Dana 50. I read that if I put a fish plate on the inside I would have to move the steering box a inch or two to the right along with the steering column?
Im going to look into mounting a bracket. The crack is about an 1/8th of an inch. Hoping it wont recrack again.
Old Nov 13, 2021 | 11:01 AM
Wheeler.M1's Avatar
Wheeler.M1
By any chance, would steering stabilizers help any? I don't know much about them at all except all those ugly sky high trucks have em.
Old Nov 15, 2021 | 07:38 PM
540milotalon's Avatar
540milotalon
I am a retired machinist and not a welder but that looks like any type of weld would be fine, like mentioned earlier, quit driving and repair. If you can “fish” plate or box it, do it. I will look tomorrow at one of mine and see if I have any different suggestions.
Old Nov 15, 2021 | 07:44 PM
Wheeler.M1's Avatar
Wheeler.M1
Thanks, it's been sitting on blocks getting degreased. Hoping I do the right weld, I'm thinking a stick weld has the best penetration for it. As for a fish plate, I've been looking at it and it'll be difficult. I have the shock bracket about an inch to the right, then on the left is bends inward. Underneath I have rivets from the cross member. Then if I wanted to weld the inside I'd have to remove the steering box and get some larger bolts...ahhh its so much. I'm thinking I'll out an outside fish plate that's about an inch and a half long. I want to rebuild the truck eventually from the frame up. So it'll be a semi-permanent fix and I can get at it better later next year in the summer.
Old Nov 15, 2021 | 07:50 PM
540milotalon
What geographical area you located?
Old Nov 15, 2021 | 08:14 PM
Wheeler.M1's Avatar
Wheeler.M1
Texas. Going to strip the chassis and do a complete rebuild outdoors. Not have to worry about rain and all as I have no work shop.
SkySkiJason
Aug 3, 2024 03:05 PM
FONRDAY
Aug 15, 2020 05:23 PM
StrokinIT2001
Dec 30, 2017 08:38 PM
Jocaren
Ford Truck Parts for Sale
Nov 15, 2011 11:57 PM
Mil1ion
Dec 19, 2007 11:41 PM
