- New IDI Here
- Really pleased with my fuel economy
- New diesel owner need glow plug help!
- What are these worth in your area?
- Engine Light Troubleshooting, Sensor Testing
- Drove turboed for the first time
- Axle pivot bushing and bracket, maybe balljoints
- Thank You IDI Forum!
- 7.3l with c6 flexplate question
- Its getting hot in here
- 88' roalin too much coal
- Need some advice
- Finally did it -- coolant drain, flush, replace
- 7.3 ip help
- Useful Links
- 7.3 IDI non turbo to turbo swap!!
- Run away diesel tread!
- Whining rear end
- 093 Install help
- Rear Antilock
- Quick fuel filter question
- What is this?
- Starting problems ..Sensor?
- What pyro are you running?
- thanks Russ
- Lift pump left running on 6.9 IDI?
- 1994 7.3 OD light flashing
- 1989 F250 7.3L IDI fuel gauge stopped working.
- Superlift for IDI?
- Clutch has started slipping.
