What pyro are you running?
Old Apr 13, 2013 | 10:24 AM
Gettysburg150's Avatar
Gettysburg150
I'm wondering how bad I need to invest in one. I've seen them @ $150 and was wondering what everyone is running and how much I need to save to get one.
The PO told me that the pump is turned up 1.5 flats. I cant confirm this.
The truck only smokes the slightest bit on heavy accel going up a hill, little bit of gray smoke during cold start/warm up.
I'm worried about EGTs but from what I read it doesn't sound like I got a whole bunch of fuel getting dumped in. What do you think?
Thanks
Old Apr 13, 2013 | 01:05 PM
turtlemann14's Avatar
turtlemann14
issopro i think is the most common.
i am running a glowshift, but i don't know how long it will hold up.
Old Apr 13, 2013 | 01:07 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Banks/DynaFact Pyrometer #64008
running a intercooled 800ish egt peak.
Old Apr 13, 2013 | 07:47 PM
monte97z's Avatar
monte97z
I'm running glowshift, was about 100 bucks. Seams OK for my use, not dd and usually trips are less then 50 miles. If I was heavy hauling or doing extended drives regularly I'd prob invest in a better one. But I'm happy with it
Old Apr 13, 2013 | 08:06 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
holy crap! i knew my IP was junk but didn't know it was that bad. i only hit 800 if i am in O/D lugging the **** outa it. Damn! can't wait till i get my new IP!!!!
to keep my post on track LOL, i have a glowshift pyro. i would get isspro if i had it to do again. nothing really wrong with my glowshift but the quality is not nearly that of isspro.
tecgod13's Avatar
tecgod13
Isspro, I got it lightly used off ebay. But its worth buying new, I just happened upon the deal. I want to say Isspro makes a lot of pyros for the big trucks...
Depends on who talk to, but I think Glowshift is has an extra 'f' in their name...
Old Apr 13, 2013 | 09:54 PM
kobaltblue's Avatar
kobaltblue
Isspro here too, Watch out for the "Less priced" versions they dont come with the "other" parts.....I dont know whats up with mine it can easily peg 1000* IP @7psi been turned down 2 flats and it still gets hot....Dont know how much these turbo pumps push but its still got alot of fuel.
Old Apr 13, 2013 | 10:11 PM
kla94's Avatar
kla94
Mine hits 1000* wot from dead stop to 5th up a steep hill empty. 400* cruising. I'm pushing 80ccs of fuel and 10psi of boost. Not a whole lot of difference loaded with 2 rank of green firewood.
Old Apr 14, 2013 | 08:22 AM
FORDF250HDXLT
im only 300 egt running 45 mph when empty (8k lbs.)
the 800 is "peak" loaded (13-18k gross) wot uphill.
Old Apr 15, 2013 | 12:45 AM
idiabuse's Avatar
idiabuse
Auto Meter pyro
1000F maybe more
15psi+ need a 20psi gauge now
try and keep around 10psi for safe keeps
Javier
Old Apr 15, 2013 | 12:59 AM
whiteboyslo's Avatar
whiteboyslo
Keep in mind the probe location makes a big difference in readings. Temps in the manifold will be hotter than those in the Banks location (near the turbo).
Mike
Old Apr 16, 2013 | 07:56 AM
Chevy_Eater's Avatar
Chevy_Eater
I like the looks of this Hypermax combo gauge:
Hypermax - Product Display
Of course I'd never be able to justify $250 for a gauge, nor would I want to, so it's never going to happen in my truck.
Old Apr 16, 2013 | 08:00 AM
Gettysburg150
Well I was considering the hypermax combo. I do like the 2 in one and it would go with the hypermax parts already in the truck lol. But Im not sold on the price tag either.
Old Apr 16, 2013 | 08:51 AM
whiteboyslo
Not a bad looking gauge, but considering most turbos for our trucks wouldn't use HALF that boost range, I'd say it's overkill.
I use a Autometer Sport-Comp (digital) EGT gauge, but it's not working right. I tried to get cute and make it work with the pyro in the stock Banks location, so now I have to order a whole new wiring harness, tap the manifold, and do it right like I should have done in the first place.
Mike
Old Apr 16, 2013 | 11:47 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Mike
Im thinking its a decent price, two gauges in one. Secondly, do you ever overheat your engine? I hope not, so why then does the temp go to 260? The 30lb boost guage wont hurt anything, beyond that good luck finding one < 30lb thats not a POS vac. / boost.
