Engine Light Troubleshooting, Sensor Testing
Old Apr 14, 2013 | 07:45 PM
Screwzer's Avatar
Screwzer
OK, first post here after lurking and getting most of my questions answered.
1988 F250 7.3 IDI
I cleaned my engine yesterday with simple green and a hose. Started fine and it runs great, but now the red engine light is on and the temperature gauge is pegged.
The guage sensor is shot for sure, because when I pull the connector it returns to normal. Pulling the overtemp sensor on the driver's side doesn't do anything, with or without the other sensor plugged in. How do I test it?
Next suspect is the oil pressure sender behind the air cleaner. The gauge seems to work. How do I test it?
Ditto for the temperature sensor with two wires that controls the engine (behind the alternator). Is there a way to test this?
One more question: I have a sensor by the oil filler at the front of the vehicle. I thought that was oil pressure, but posts I've read indicate its in back.
New truck to me, and its my first diesel. Going through and cleaning it up now....
Old Apr 14, 2013 | 08:15 PM
Forddiesel17's Avatar
Forddiesel17
the sensor by your oil fill would be your tach sensor. the gauges in these trucks suck. i would advise you put some aftermarket gauges in to better monitor you engines functions. ex. the oil pressure sender on these trucks are just an idiot light. they do not show actual oil pressure just if it has enough to close the switch. so you could have four pounds of pressure but the gauge shows it ok because of the way the sender is.
Old Apr 14, 2013 | 10:09 PM
The_Josh_Bear's Avatar
The_Josh_Bear
Firstly, welcome to the Forum!!
Did you have a hot engine, or cold? Be careful with cold hose-water around a hot IP! That can lead to damage that costs around $450 plus labor...
Yeah as Forddiesel17 said, certain gauges in these trucks are just on/off switches. I found personally that my temp gauge reads great when it's unplugged, lol!
As for testing it... I suppose if it registers normal it's working?... again, they suck. The coolant one moves around a bit, but doesn't actually read temperature. I have a real gauge now and the stock one doesn't even correlate a LITTLE BIT to the real one.
Also just an on/off switch. If it reads, it's "working". But I've read that it switches ON with only 6psi, which is too low for these trucks, even at hot idle.
Ok, this is where you lost me. These engines are 99.99% mechanical. The only electrical bit that "controls" it is a simple fuel-shut-off solenoid, and that's on the driver's side of the IP.
Hope this helps,
Joshua
Old Apr 15, 2013 | 04:27 AM
tjc transport's Avatar
tjc transport
i ain't rite
give it about a week for the temp sensor to dry out and it will start working again.
there are only two things hat will pop the check engine light, low oil pressure and high water temp. since you know it is not running hot, just let it dry out.
Old Apr 15, 2013 | 06:07 AM
Screwzer's Avatar
Screwzer
Huh. I like that fix.
Real gauges are a low priority now. 1st, I need a clutch.
Old Apr 15, 2013 | 06:12 AM
Screwzer's Avatar
Screwzer
Hope this helps,
Joshua
The one behind the alternator I thought was used to set fuel mix.
Could be wrong.
Was wondering if it would affect fuel economy.
Mine seems to work, sine I get fast idle at start at 950 rpm. Comes down to 77 ish once she's warm
Old Apr 16, 2013 | 10:19 AM
Screwzer's Avatar
Screwzer
OK, the oil and two coolant sensors on the driver's side didn't dry out and Im gonna replace 'em.
question on the two-prong sensor for the solenoid: Is this just a simple switch I can check for continuity, or does it provide a rheostat like function as temperature goes up?
Figured I'd replace them all, but this one's dealer only it seems while the others were under $20 each.
Cheap insurance, since I gotta drive this beast 1500 miles this weekend.
Old Apr 16, 2013 | 05:08 PM
tjc transport
i ain't rite
the one under the alternator is a temp switch. once the engine reaches 110 degrees(i think it is) it will turn the high idle and timing advance off.
Steven Stocki
Dec 10, 2016 09:23 PM
GRoke7.3
Jul 18, 2015 09:30 AM
icesimpson
May 16, 2014 08:25 AM
workingdog
Jun 15, 2006 09:10 AM
mudd12
Electrical Systems/Wiring
Mar 26, 2004 08:10 PM
