Rear Antilock
Old Apr 13, 2013 | 03:01 PM
mlouritt's Avatar
mlouritt
Rear Antilock
I have a 1990 F350 4X4 with the Ford 10.25 rear axle. I am getting a "Rear Antilock" dash warning light coming on intermittently. What is causing the warning and how do I correct the problem?
Old Apr 13, 2013 | 06:37 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
intermittent light is probly a loose or chafed wire. would need to get a wiring diagram and then ohm(resistance check) the wires in the ABS system.
Old Apr 14, 2013 | 07:48 AM
bashby's Avatar
bashby
Check for codes. Heres how: How to: Retrieve ABS trouble codes - Ford F150 Forum - Community of Ford Truck Fans
Old Apr 14, 2013 | 09:27 AM
mlouritt's Avatar
mlouritt
Originally Posted by bashby
Thanks for the link. I will start checking this afternoon after work. After reading the link it sounds like it could be a lot of fun
My brake warning light has never come on when the Rear Antilock warning light is on, so at least half of the troubleshooting is likely eliminated. Thanks again!!
BS51993
Aug 5, 2018 09:15 PM
Prozon
Feb 3, 2009 10:45 PM
handsomerob
25
Sep 21, 2007 07:43 PM
cuztom79
May 17, 2007 11:28 PM
fishindave11
Bronco II
Jan 21, 2006 06:52 PM
