Vacuum advance question
Old Apr 6, 2010 | 10:26 AM
Nathan Plemons's Avatar
Nathan Plemons
99% of the time when I see a picture of a vacuum advance, there is only one vacuum line going to the canister right in front. My canister has a second fitting pointed straight up. It has been capped off. I am curious if this is supposed to go somewhere, or if maybe the canister has been replaced at some point. I do not see a number on mine anywhere, but it is a genuine motorcraft.
Any thoughts? '74 302 with in a F-100.
Old Apr 6, 2010 | 11:36 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
It's a dual vacuum advance, the other port retards advance during starting, Don't worry about it.
Old Apr 6, 2010 | 01:58 PM
Nathan Plemons
Explains why it runs just fine. I would gladly hook it up if I had any idea where it went.
Old Apr 7, 2010 | 08:27 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Going by my feeble memory, it hooks to a ported vacuum switch close to the thermostat housing. It's actually temperature controlled. There was another delay valve that looks like a small inline fuel filter like you see on a lawnmower. Different colors for diff amounts of time delay. Never found one with everything hooked up.
Old Apr 7, 2010 | 08:37 AM
Nathan Plemons
I was told that the temperature controlled line went to the EGR, which is not connected because my EGR wouldn't work even if it were connected. I have the temperature switch, but nothing is connected to either end of it.
I know there are supposed to be several vacuum lines running around the original air cleaner. My flexible ducting was in bad shape though so I did away with all of that stuff and just put a regular air cleaner on it. I would have have to look to make sure, but honestly I think there is only one vacuum line on my whole engine and that goes from the carb to the vacuum advance. I know all the ports on the manifold are just capped.
whitesdford
Mar 4, 2013 10:19 PM
Nick Greer
Aug 2, 2012 08:28 PM
Dusty Wooddell
1983 - 2012 Ranger & B-Series
Oct 15, 2011 07:37 PM
CATANG MOTORSPORTS
Sep 21, 2008 10:48 AM
