Carb gasket burned up???
Does the intake spacer have the inlet for the EGR? If that's the case, you will have to find an aluminum gasket for that interface. Exhaust gases are very hot, and will burn up paper gaskets in no time.
On the EFI cars, the EGR inlet is right behind the throttle body, and Ford runs coolant through it to help remove some of the heat.
GeneGregory
11-09-2016 03:39 PM
ClatonK
01-19-2004 12:28 AM
stephenw
02-08-2001 05:59 PM
