Hesitation from stop
Old Nov 28, 2011 | 02:13 PM
84 Bronco's Avatar
84 Bronco
I posted this in the Bronco forum and think that was in the wrong place.
My 84 Bronco with a 302 has a hesitation I have not been able to diagnose. I had the 2 barrel carb rebuilt by Ford and just replaced the vacuum advance. It runs great at idle and once moving. I suspect it is vacuum related. Anyone else have a similar issue? It has all the original emission control intact. I'm bringing it home this weekend to replace the exhaust and want to get this fixed also. Thanks!
Old Nov 28, 2011 | 03:46 PM
HemiEater's Avatar
HemiEater
I would check the accelerator pump linkage... make sure it's tight and has no slop in it.. also check the squirter make sure it is sending 2 streams of fuel down into the carb, do this with the engine off. check timing.
go to the Holley web site they have some good instructions on setting them up
Old Nov 28, 2011 | 05:54 PM
84 Bronco's Avatar
84 Bronco
Good tips. Thanks!
78 Ford F150 460
1978 - 1996 Big Bronco
42
Jan 24, 2017 08:05 PM
adamdunn86
Jun 23, 2014 01:49 PM
84 Bronco
Nov 28, 2011 06:02 PM
jwc9261
Sep 17, 2011 07:45 AM
doop
Aug 5, 1999 08:24 PM
