390 Hp from factory
Old Mar 5, 2001 | 01:21 AM
fearthis390's Avatar
fearthis390
390 Hp from factory
Hi i was wondering if anyone could tell me what the power of the 390 was from the factory. Also i know im not in the right forum for this but my truck has a sticker on it that says it was transported from canada i was wondering if anyone knew anything of this thanks
T.J. Flynn 1979 F-150 390 4spd 4x4 lock stock and barrel for now
Old Mar 5, 2001 | 10:33 AM
karljay's Avatar
karljay
390 Hp from factory
Stock ratings for the 390 are from about 265 to 401. Most are in the 300HP range. The later years and trucks got lower compression and 2v setups, the 401 was a 3X2 carb setup. Making 325~400 is not hard with a few mods, the Edelbrock setup makes about 418HP with intake, carb, headers, heads.
Old Mar 5, 2001 | 11:16 AM
buzzard's Avatar
buzzard
390 Hp from factory
Your '79 didn't come stock with a 390 unless things were different in Canada. Ford quit using the FE's in '76 in the U.S.
To answer your question, stock 390 truck engines came with around 255 HP and 375 ft./lbs. torque.
Old Mar 6, 2001 | 10:24 PM
fordmann's Avatar
fordmann
390 Hp from factory
71 was the last decent year for the 390 in trucks with 255 HP. 72 was 201 HP and 73 was 195 HP. the 76 360 which is the same block just different stroke was rated at 143nhp. Pretty **** poor. In comparision the 68 390-2V was at 280 HP. The 401 HP 390 was in the early 60's. 61 to 63. If you can't find a pre 70 engine at least try and find the heads from one. Hope this helps! Fordman
Old Mar 7, 2001 | 12:14 AM
FE427TP's Avatar
FE427TP
390 Hp from factory
heads from 65 and earlier will have the taller ports
Old Mar 7, 2001 | 11:43 AM
buzzard's Avatar
buzzard
390 Hp from factory
Hey Fordman, what is your reference for the '68 390 HP numbers. I'm more curious than anything because I've got a '68 Ford published specification book and it lists the 390 at 255 HP and the 360 at 215 HP. They didn't offer a 4V in the trucks so I was thinking your HP number might be for a 4V car engine?
Thanks.
Old Mar 7, 2001 | 03:01 PM
fearthis390
390 Hp from factory
Well I have found out recently that my engine is out of a 68 Merc but thats it so i guess its not Lock Stock and barrel after all
Old Mar 7, 2001 | 06:40 PM
fordmann's Avatar
fordmann
390 Hp from factory
Chiltons Truck and Van repair manual 71-78. That 255 was for a 2V not a 4V. 70-71 was 255, 72 was 201 and 73 was 195. All truck motors at 4400 RPM.
Also out of the High Performance Ford Parts Interchange book are these numbers for the 390:
401@6000rpm (6V/hp) 61-62
265@4400rpm (2V) 62-63
275@4400rpm (2V-PI) "
315@4600rpm (4V) "
320@4600rpm (HP/GT)
Chiltons full size Ford cars. The below information was provided solely by Ford Motor Company:
For 68.............
390-2V 270@4400 Torque 390@2600 ft.lbs.
390-2V 280@4400 403@2600
390-4V 315@4400 427@2800
Old Mar 7, 2001 | 06:44 PM
fordmann's Avatar
fordmann
390 Hp from factory
Those numbers could be wrong I'm just reading out of the books I have. Let me know something if I'm right or wrong.
Old Mar 8, 2001 | 12:05 AM
HiMe's Avatar
HiMe
390 Hp from factory
Be careful with those Chilton's manuals because I've seen some rather blatant errors in them. All they really do is just copy certain pages from the "real" Ford vehicle manuals and sometimes don't paint an accurate picture. I'm not exactly sure how they get their info screwed up but they do.
Jim
Old Nov 19, 2002 | 07:56 AM
C_J's Avatar
C_J
390 Hp from factory
Where can I can "official" hp and torque rating figures
for FE engines. I need an FE with as low horsepower rating as possible, but the rating would have to be verifiable.
Our government just allows 6.8 hp / 100 lbs car weight
so I have to have a replacement engine for my 427 HR
when going to the mandatory yearly safetycontrol.
Is the 1976 360 the lowest in hp?
Thanks
C-J, SWEDEN
Old Nov 19, 2002 | 05:26 PM
gtex's Avatar
gtex
390 Hp from factory
[updated:LAST EDITED ON 19-Nov-02 AT 06:27 PM (EST)]Why are the ratings on the door tags so much lower? I know the 68/68 360 and 390 read at 172 and 185 HP. I guess that is net engine HP (including all accessories/pumps)? I don't belive they ever measured rear wheel HP.
Old Nov 29, 2002 | 08:24 PM
traisor's Avatar
traisor
390 Hp from factory
>4V car engine?
>Thanks.
I have a 1976 F150 with a 390 4V, I'm sure it came from the factory that way.
Tom in Ky.
Old Nov 29, 2002 | 11:01 PM
Ratsmoker's Avatar
Ratsmoker
390 Hp from factory
You are correct. Ford did offer a 390 4V in 76. You can tell the manifolds they used by a large "T" on top of it.
Old Nov 30, 2002 | 08:36 AM
dinosaurfan's Avatar
dinosaurfan
390 Hp from factory
Don't worry about the factory power rating. It ain't important. The reason the later 72?-79 FEs are less powerful is because the compression hieght was reduced on the pistons. When you're rebuilding, using the right pistons will bring power back up. In the US, alot of trucks were made in Canada. The 4x4s all got 352s or 360s. 390s were offered 1/2 and 3/4 tonners till 76, in 1 ton or heavier till at least 70. If the truck was intended to be sold in Canada, I don't know what the engine availability was. Might very well be differant from US. :-) DF
