360-460 conversion
Old Mar 9, 2001 | 12:11 PM
larbuck's Avatar
larbuck
360-460 conversion
hi all I have a 1975 f250 4x4 with a 360 and automatic tranny my question is how hard is it to switch out the 360 and replace it with a 460 i know advanced adaptors makes adaptors for the engine mounts but what about the tranny will the 460 bolt right up or do i have to have adaptors for it also any suggestions would be very helpful thanks
Old Mar 9, 2001 | 12:36 PM
rusty79's Avatar
rusty79
360-460 conversion
For your transmission you will have to replace it with one from a 351m, 400 or 460. The bellhousing bolt patterns are diffent between the 360 and 460.
Old Mar 9, 2001 | 12:50 PM
larbuck's Avatar
larbuck
360-460 conversion
the problem with replacing the tranny is its a automatic with a divorced np205 the tranny is a c6 but its really short can i still use the automatic tranny even though its from a 460 family
Old Mar 9, 2001 | 02:33 PM
dinosaurfan's Avatar
dinosaurfan
360-460 conversion
Larbuck, hold on a minute here, why would you want to do this? The 360 might need some help, but a 460 would require a new trans as well, and they are heavy! How about considering a 390 as a replacement? A healthy 390 will have more than enough power, and is a simple drop in replacement for your 360, and, it is the right thing to do. DF
Old Mar 9, 2001 | 03:34 PM
buzzard's Avatar
buzzard
360-460 conversion
I struggled with this issue and finally decided to upgrade to the 390 rather than *******izing my '68 truck with the 460. My 390 makes tons of power and, like DF said is "right." If you insist on installing the 460, you're probably better off by finding a complete donor truck and harvesting all the items you'll need for the swap. This has got to be the easiest way rather than trying to wing it.
Old Mar 11, 2001 | 08:38 AM
larbuck's Avatar
larbuck
360-460 conversion
all right you guys talk me into it ill keep the automatic and find me a 390 after reading some orther post it seem like to much of a pain in the a** espically with the divorced t-case thanks for helping me make up my mind
louis
Old Mar 11, 2001 | 08:55 AM
karljay's Avatar
karljay
360-460 conversion
