Oil changing questions
Old Oct 3, 2002 | 07:03 AM
75explorerxlt's Avatar
75explorerxlt
Hey ya'll. I have a 390 in my 75 f-150. As you all know, the oil drain plug is right on top of the crossmember. Do you guys have any tricks or hints as to how I can change my oil and not get the stuff EVERYWHERE. I was going to install one of those FRAM quick drain plugs but there is not enough room. I was just curious how you guys change the oil in your trucks. Thanks for any input!
Old Oct 3, 2002 | 11:19 AM
freeky1's Avatar
freeky1
Pull the engine. It makes it really easy to change the oil...LOL. Just kidding. I used to have a '74 F150 with the 390. I had the same problem and never found an easy way.
John
Old Oct 3, 2002 | 11:30 AM
Ratsmoker's Avatar
Ratsmoker
It might be funny but its the only way. Just spray some oil eater on to the crossmember to get the stuff off. Even the trucks up to 96 were this way.
Old Oct 3, 2002 | 11:42 AM
artskyd's Avatar
artskyd
I have taken the lid from a Nestles'Quick container..(yellow and oblong)... and cut the edge away from one side. It just fits between the cross member and the oil pan. Let it overhang just a little on the cross member. Slowly remove the drain plug and the oil won't over flow the lid and runs off into the catch can. Works for me!
Old Oct 3, 2002 | 11:47 PM
mlf72f250's Avatar
mlf72f250
