- Rotors
- Hard to shift 4spd. 86' Ford F150 300I
- I6 oil amount
- Steering Damper
- 1984 F150 Short Bed 4x4
- Suspension lift
- 1986 f150 4x4 clutch slave bleeder?
- Cummins
- 86-87 Exhaust Differences?
- speed sensor
- Need Help with Oil Pan
- F150 Auto Transmission Help
- sending unit
- Transfer case issues
- Looking For One
- 1980-1986 weatherstripping source
- Thinking about converting to propane
- Is it a big job to install a tach?
- How can you tell if 1st gear is a granny gear?
- 84 Ford specs
- intake manifold
- Wiring harness for 84 F-150
- A/C Cycling....Too Often ???
- 385 series big block 6.1 litre
- Gaskets
- Locked Out
- Vacum Hoses
- Parking Brake not Disengaging
- No tags, NO idea engine size
- Too much input.....NO ANSWER
