intake manifold
Old Mar 24, 2007 | 01:59 PM
5.8 Ford's Avatar
5.8 Ford
intake manifold
I just bought an edelbrock toker ll intake manifold for my '83 351W. It doesn't have a spot for the EGR components anywhere. It also doesn't have the vacuum line ports on the front of it just below the carb. How do I put it on?
Old Mar 24, 2007 | 02:31 PM
ReAX's Avatar
ReAX
Edlebrock has throttle body plate for the EGR. Depending on you TB dia here are the pns
3827 65mm
3828 70mm
3829 75mm
BBK's version appears to have vacume ports on it as well.
Old Mar 24, 2007 | 06:28 PM
kermmydog's Avatar
kermmydog
Smile
Is this a CARB or a TB? I don't think a Torker II was built for smog. Why a Torker II? Isn't that a single plane manifold. I'm guessing your putting it on a built 5.8L because you will need some horsepower to make up for the loss in torque.
Old Mar 24, 2007 | 09:12 PM
Franklin2's Avatar
Franklin2
I was looking at one myself, simply for the reason they sell a lot of them on ebay. They are supposed to be "inbetween" a single plane and a dual plane. They are a single plane, but it has very small runners going from the open plenum area into the heads.
I chickened out and bought a Ford cast iron 4 bbl intake instead. $10.00 + $36.00 shipping.
Old Mar 24, 2007 | 09:18 PM
kermmydog's Avatar
kermmydog
Thanks for info on the Torker II. So how are they suppose to work on a stock type engine? How much is the bottom end effected by running them?
Old Mar 25, 2007 | 02:10 PM
Franklin2's Avatar
Franklin2
Sorry, I made a mistake. For some reason I thought about the old "streetmaster" intakes they don't make anymore.
Your correct, the torker II is going to be terrible on a truck, unless the engine has been highly modified, and the rearend gears have been changed. It's going to be very soggy on the lowend.
Old Mar 28, 2007 | 09:15 AM
5.8 Ford's Avatar
5.8 Ford
Hey, thanks for the advice. So what manifold would you guys recommend?
Old Mar 28, 2007 | 01:19 PM
Franklin2's Avatar
Franklin2
Any manifold with the divider in the middle(dual plane). The original manifolds had 4 seperate holes and the aftermarket ones usually have two long slots where the carb sits.
