- Intake Manifold Gasket replacement
- T-17 ft clutch installation
- Pinion sleeve?
- C6 Rebuild
- Red Head Steering Gear
- 351W drain plug size?
- 80-86 f150 lift
- Steering
- Propane & Feedback Carb
- What sensor malfunctions will throw the computer into Limp Mode
- i have an 86 f150 sportsman, whats the sportsman mean?
- trying to find a part.
- Failed Emissions Test
- Shock setup recommendation's...
- What can cause the DS front brake caliper to lock up?
- rear end gear changes?????
- Engine Dilemma
- distributer/starter?
- 85f-150 2wd
- carb backfire
- vacuum lines?
- duraspark conversion idle issue
- Engine Block Ground
- Problems with a 86 f150
- E-15 on the horizon?
- Key cylinder
- 1985 F250 4x4 gas gauge doesn't work
- Oil issues
- Installing new TPS on '85 4.9
- A few misc questions.
