- Transmission Swap
- found a monster
- Added oval running boards
- Different tranny
- Dash swap
- gross vehicle weight
- Front End Issues
- Found a cracked brake rotor tonight.
- Engine has a knock
- Shifting problem on a 86
- New motor no vacuum
- Trying to fix some donor seats
- Clutch Fork Removal
- Header for I6 300ci
- new wiring
- Help, Need Ideas Replaced clutch has problem
- 6.9 swap
- opinoins welcome
- 85 F250 brake problem
- T-case Shift bar, "clip" holder needed
- converting 2wd to 4wd
- slave cylnder install?
- Driver front blinker not working, everything else does
- No electrical power
- Instrument Panel Gagues
- looking for pics
- Front Passenger Side Axle Removal HELP.
- tach help with aftermarket ignition - 1981
- one freaky wire and some vac lines
