- Need your opinions / efi vs carb
- Need Some Help Replacing Heater Core
- replacing 4 speed with a five speed problem!
- Fuse keeps Blowing
- instrument panel lights not right
- specs on air pump needed
- 84 F150 supercab door panels
- In Search Of....knowledge so common it's hard to find
- Weird Electrical Problem need help
- need info on tow weight capacity
- Need Help On Motor Type
- How To determain motor need halp bad
- Clutch travel...
- pto pump
- Bogging out...HELP!...PROBLEM SOLVED
- gearing Q's
- older Ford Truck parts support- NOT GOOD !
- Coupla' quick timing and general questions about an '85 460
- Another old Ford returns to the road ...
- C6 to 4 spd swap
- 300/6 Dist. breaks wrist pin
- Vacuum leak from brake pedal?
- Transmission and Differential ID for 85 F150
- Have a lighting problem
- bogging out...Help
- C6 tranny fluid
- What Happened! It Went Bang!
- Wheel offset?
- Four Wheel Drive Problem
