No tags, NO idea engine size
Old Mar 23, 2007 | 03:18 PM
Jason A. Robertson's Avatar
Jason A. Robertson
The firing order indicates 351 or 400. Ok 351w,351c, or 351m. Small block , big block? Thanks
Old Mar 23, 2007 | 04:23 PM
mhg's Avatar
mhg
F-what
19 what
must have info
Old Mar 23, 2007 | 04:51 PM
mhg's Avatar
mhg
OK i now see the other post
the best way to get an id is a picture
need one of the valve covers and one of the base of
the distributor
Old Mar 23, 2007 | 10:19 PM
1pump's Avatar
1pump
All I could tell ya for sure right now is that it's not a Cleveland.
Old Mar 23, 2007 | 10:54 PM
WA1986F-250's Avatar
WA1986F-250
Talking
Originally Posted by mtflat
6 - 351W
7 - 460
8 - 351M/400
I just learned this today
Old Mar 23, 2007 | 11:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Only years for 351M/400 in F100/350's= 1977-1982
NO F Series truck, Bronco or E-van ever used a 351C. Rancheros only.
8th digit in 17 digit VIN's is the engine code.
Old Mar 23, 2007 | 11:08 PM
NumberDummy
Those are numbers of valve cover bolts, not engine codes.
Only V8 gassers in 1983-1989 F series or E-vans: 302/351W/460
Old Mar 23, 2007 | 11:27 PM
NumberDummy
Originally Posted by Jason A. Robertson
The firing order indicates 351 or 400. Ok 351w,351c(no 351C's ever), or 351m. Small block , big block? Thanks
Welcome to FTE What is the year? 1985? NO 351M/400 after 1982. NO 351C ever!
Please~~we need the year/model/engine/transmission type when y'all ask questions. Listing the VIN helps too.
Old Mar 23, 2007 | 11:50 PM
mtflat's Avatar
mtflat
His other post had more info - indicated that someone may have swapped engines and now it's an unknown. Here's the link
https://www.ford-trucks.com/forums/5...no-answer.html
Old Mar 24, 2007 | 04:39 PM
Franklin2's Avatar
Franklin2
You guys haven't hung around here enough. People write in; "How do I wire up a 1978 400 in my 1995 f150?" "Does anyone have any experience in putting a 390 into a 1986 f150?"
Old Mar 24, 2007 | 06:19 PM
Mil1ion's Avatar
Mil1ion
Okay.... I'm here now.
Jason. Grab a pen and some paper
write down
Number of valve cover bolts on each valve cover.
Next:
write down the ALL the casting numbers off the
Heads (see oil galley)
Block just up from starter
Intake manifold
They look like this somewhat.
Old Mar 25, 2007 | 05:33 AM
82F1507.5's Avatar
82F1507.5
Chuckle.....nope!
