I6 oil amount
Old Mar 26, 2007 | 09:39 AM
86_F150_I6's Avatar
86_F150_I6
Smile I6 oil amount
hi i have a 86 4.7L I6 f150 & the first & the last time (3000 mi ago) i changed my filters & oil i spent about an hour and a half just adding & checking the oil to get it to show on the stick & i dont recall how much oil i put in it...i think i put in 6quarts but im not sure can someone tell me how much i should put in so i dont have to waste so much time on the oil change this time???
---also when i slow down and i get to about 5mph i hear a rather loud CLICK/clank everynow & then.. is that ok or "normal" for an old truck?
Old Mar 26, 2007 | 09:57 AM
Franklin2's Avatar
Franklin2
A loud noise is never normal for any vehicle no matter how old it is. It could be anything though. You need to try to relate it more to what's going on like;
It does it always when you slow down. Is it always after you use the brakes, or will it do it when you just let it coast down?
It does it automatically or it only does it as you start to hit the gas to speed back up?
I am not sure about the oil, I could look it up in a book but sometimes I don't trust the book. Someone with a six will know, or what you could do is just fill it up with 5 quarts and then run it. I know it takes at least 5 quarts. After you run it and let the oil settle, then if its on the add mark, then add one quart, and you know it takes 6.
Old Mar 26, 2007 | 05:38 PM
Dungeon_Master's Avatar
Dungeon_Master
I have 2 4.9 I-6's. I put in 5 quarts plus 1 bottle of duralube high mileage treatment. It can depend on the oil pan. If someone installed a deeper pan it would be 6 quarts. Factory would be 5 quarts. I would follow Franklin2's suggestion.
Old Mar 26, 2007 | 06:18 PM
Big John Hance's Avatar
Big John Hance
I have a 4.9L i6 with the stock oil pan, and it takes 5 quarts.
Old Mar 27, 2007 | 03:10 PM
Holmesuser01's Avatar
Holmesuser01
I had an '84 with the stock 300 six. I always added 6 quarts, along with the new filter. It put the level about 1/6" ABOVE the full mark. Ran it over 450K this way.
Old Mar 31, 2007 | 11:49 AM
86_F150_I6's Avatar
86_F150_I6
sorry ihavent checked this site i been extremely busy looking at side jobs with this good weather --- about the noise it SOmetimes does it and its usually when i brake hard and it makes the clank when i get down to like 8-5mph doesnt do it if i roll to a stop ---thanks for the input on the oil
Old Mar 31, 2007 | 08:24 PM
hoxiii's Avatar
hoxiii
Oil quantity does depend on the pan (and even the dipstick), but most 80-96 300's use 6-7 qts on an oil change depnding on the filter you use. Using the full size filter the 300 I had held a full seven quarts.
BUT, the oil pan on my truck doesn't match the block. I have an in-block and an in-pan dipstick, and they disagree by a full quart. The in-pan stick needs 7 quarts to read full, the block stick needs 6 quarts to read full.
As for the noise, check your driveshaft u-joints and your transmission mount. They make clunks like you describe.
Justin
Old Mar 31, 2007 | 09:10 PM
Franklin2's Avatar
Franklin2
I would check the rearend and the springs to make sure everything is tight. I would also take the rear brake drums apart to make sure everything is kosher there too.
Old Apr 2, 2007 | 04:16 PM
86_F150_I6's Avatar
86_F150_I6
Thumbs up
i've never dealt with drums yet and i've seen it done once back in the day and i decided i woudnt try it myself haha but the brakes do need to be changed soon they're beginning to squeek on the so i'll shake some stuff around and see if everything is tight while i make my attempt haha
