- 300-I6 Spark Plug Gap
- Exhaust mod,
- Leaking Steering Gearbox
- Air Conditioning blows out wrong vents
- Modulator Valve
- fuel pumps
- Still not running after all this time!
- Rear Gear Swap
- A/C Reduces MPG?
- Check Engine Light Not Working
- Power/Torque Struggle
- 81 F-100 Styleside
- power steering
- AOD trouble
- transmission extensions problems
- Dead spot
- F350 Dually 460 Power Steering Pump
- ABS computer?
- air silencer
- electrical problems
- idle drops heavily in gear
- Fan Switch
- Short???
- Starter Problem!!
- 460 exhaust system
- ENGINE PLENUM
- New switch fixed Max A/C Problem
- Oil Coolers
- Loose Spring Bolt/Corrosion
- 5.0 Throttle Tension
