- Coil Spring Replacement Options?
- Oil light issue
- manifolds vs shorties
- about a hyraulic - manual clutch assembly (80-83)
- timing degree
- Caliper bracket question
- 1986 F-350 front axle vibration
- 1985 F250 Regular Cab, Matte Black Rattle Can Job.
- No brake lights,when headlights are on
- Yet another problem with the 1985 F250 351w backfiring through exhaust
- Rim conversion
- Sprayable solvent cleaners ...the inexpensive way!
- Addios bullnose team.
- solution to paint drying a diffrent color on bondo
- Engine bolts
- 300 coil mounting
- 83 F150 Oil leak-leaks pan gasket?
- Hi! Brake lights, turn signals and reverse lights are not working. AGAIN! 1985 4spd
- Build Sheet
- which way to go with dual tanks
- Clutch - any aftermarket or suggestions?
- 85 F250 7.3 idi
- Dana 60 ring and pinion
- Economical leveling kit
- one more problem to add heating?
- front spring mount
- Bruno's Carb
- 1986 F250 4wd-what front axle do I have?
- Adjustment of clutch/starter safety switch?
- Can anyone help wheel stud problem
