- 85 Steering Column Wiring Diagram?
- What transmission could this be?
- Help needed for flareside!
- Starter/solenoid advice
- Transmission swap or rebuild
- time for new radiator, need help
- Clutch Shopping
- 1985 f-150 rear bumper needed
- Gauge mount locations?
- TFI wiring hacked up, which is "spout"
- PTO
- 84 F150 swap to EFI help!
- Flareside Chrome Rear Bumper Part Number
- Is the front frame of 80-86 same as 87-91?
- Some Discoveries
- zf 5speed and possible cummins swap
- 85 300i motor help!
- brake bleeding w/ vacuum pump
- 83 ford 460 cranks slow when warm
- Cummins swap/frame question
- heater hose to manifold fitting
- Can Old Red do it? Hoping to flat tow an F350
- need EGR OEM number
- Knew I should not have looked under the bed.
- Power windows and locks switch location
- 2 Newbie Questions
- Preformance increase
- 85 f-150 stepside 4x4 5.8 gear ratios
- Dad's Engine
