- F250 wiring
- Starter wont crank engine
- C6 to AOD
- New Ignition for 84 351w HO
- 1983 f150 carb options?
- 1983 f-150 carb. options?
- Limited Slip or Not ??
- 300 six to 462 Lincoln swap
- I feel stupid but what are torque specs for lugnuts on an '85?
- another axle id
- Decoding My Trucks VIN
- alternator problems??
- dash conversion
- Can someone decode this VIN for me?
- Electrical Oddity
- I got it running and timed, still have idle problem.
- Front Brakes Sticking
- Ignition Blues?I changed a 300 out of a 80 into a 84 I used the dist. out of the 84 an the carb setu
- gas gauge
- Harmonic Balancer Good or Bad??
- straight axle conv.
- 86 150 long bed
- Looking for rear sliding glass parts
- 1983 F250 302 Long Block
- 460 bellhousing and flywheel
- Front U joint
- '86 302 EFI still with problems
- Another 351W to 302 parts interchangable?????
- throttle body
- changing limted slip clutches
