- Heater fan only operates in high speed
- 9 inch drain plug
- Cross-over exhaust pipe
- question on cleaning
- Fuel Delivery Problem Re: 85 F150 - Need Help
- 1985 F250 exhaust leak in manifold?
- 300 6 vs 302
- SHAKES BAD!
- automatic to standard
- 1980 f150 specs for super-newbie!
- Oil breather cap and PCV valve relocation
- 300 i6 to 302
- 86 F250 6.9 4X4 Axle Codes ?
- Bad torque converter or something else???
- Can the TFI coil be used with Duraspark?
- New FTE User
- Help!! truck won't hold 3000 rpm
- front stub shaft
- 86 f150 Running Rich
- f 250 cab swap
- Ford 300 timing specs
- Finished with my new motor..
- 4 Speed to Auto Swap
- Rear locker for an '84 bronco
- f-350 front axle
- new plug wires
- 84 F-150 possible Engines/trans.
- New 84 F150 Owner
- Air pump / Air tube
- engine exchanges
