- Add air pump back to 85 F150
- 1985 5.0 EFI - Tips to diagnose and fix spark knock (ping)
- Identifying Some Wires
- 30 -50 vibration motor mount 6 not verticle.
- Asking for help to identify Ford pickup truck
- crankshaft position sensor mounting
- Large vacuum line 85 F150 bbl
- Electrical problems
- 1985 ford f150 300 inline6 loss of power while driving
- 1985 Ford F-150 300 inline 6 power loss in engine while driving and sometimes at idle
- Will a 5 blade fan from a 460 fit a 302
- My 1980 Bullnose
- Rockauto code
- Cardboard... really?
- Kick Panels
- Threadlock for Idle Speed Screw?
- Can I tell the rear drum size from the VIN?
- 86 Ford F150 XLT Lariat 5.0 2WD ECM questions.
- Well, Interstate battery caused me Much Sorrow
- 85 running after carb rebuild, until…
- 1983 Beater with no heater...
- Hand Throttle?
- Low Air Through Vents
- Help with wiring HEI distributor
- NP208 Fluid Type
- Carb base gaskets
- Wierd
- mebers nearby
- Handle trim huh?
- Wheel/Tire setup
