Rotors
Old Mar 26, 2007 | 11:48 AM
SuperSnake's Avatar
SuperSnake
Rotors
I have a 81 F100. I did a search on here to see if the F150 rotors would fit on the F100 Spindles?
Old Mar 26, 2007 | 12:39 PM
texcan's Avatar
texcan
Yes, Im pretty sure they will. I think one time I got them mixed up and they worked just fine. Heck I even put a 14" car rotor on one time! Didn't notice till I was ready to put the wheel on and it was to small. I get to busy to notice the small things. LOL
Old Mar 26, 2007 | 12:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
NO they will not fit. 1980/83 F100's have 4.50 bolt circle. The only 4.50 bolt circle ever used on an F Series truck. The rotors, brakes, spindles...ALL different.
Ford was promoting the then new F100's as a "light truck."
Full sized Ford passenger cars also have the 4.50 bolt circle, but the rotors have a different part number than the car rotors.
Except 1980-81-82-83 F100's---Every other Ford F100/150 from the 1940's till the wheels went metric in the 90's has a 5.50 BOLT CIRCLE.
Old Mar 26, 2007 | 02:44 PM
texcan's Avatar
texcan
My 80 f-100 is 5X5.5 lug patern and is that way from stock. I never change a thing on that part. Is this what you are refering too, Numerdummy?
Old Mar 26, 2007 | 04:13 PM
andym's Avatar
andym
From what I have read, not necessarily all 1980-1983 F-100's got the smaller bolt pattern. There was an option package that gave you 5.5 wheels on those years. But that range was definitely the only time you could get the smaller bolt pattern on an F-series truck.
Old Mar 26, 2007 | 07:19 PM
SuperSnake's Avatar
SuperSnake
My problem is the rear has been changed,it has a 9 inch rear with the 5.5 bolt pattern and would like to change the front to a 5.5 too
Old Mar 26, 2007 | 08:23 PM
andym's Avatar
andym
Ok, assuming that Bill's right (and he usually is) then you'll need to pick up a pair of spindles from an F-150 from the junkyard.
Old Mar 26, 2007 | 08:29 PM
SuperSnake's Avatar
SuperSnake
OK thats what I will do.Will it have to be from a 80-83? I was told that Ford went to Ball joints after 83
Old Mar 26, 2007 | 08:31 PM
andym's Avatar
andym
They did - but I don't know if that will make a difference or not.
Old Mar 26, 2007 | 08:34 PM
SuperSnake's Avatar
SuperSnake
Thanks Everyone.
Old Mar 27, 2007 | 03:41 AM
NumberDummy
There is no reference to a 1980/83 F100 using anything other than a 4.50 bolt pattern in the 1980/89 Ford Light Truck Parts Catalog. The catalog makes no reference to a 5.50 bolt circle available as an option. Every brake and some front end parts are specific to the 4.50 bolt circle.
You will need not only the spindles, but all the front brake parts to convert to 5.50.
andym: Where did you read that info about the 5.50 bolt circle?
I'm just a messenger here. I type what I read in the parts books, so please don't shoot the messenger if you disagree. Ford is HQ'd in Dearborn, point your SAA's that-away.
Old Mar 27, 2007 | 07:09 AM
SuperSnake's Avatar
SuperSnake
Numbersdummy would it matter the year I get the spindle from?
Old Mar 27, 2007 | 11:14 AM
andym's Avatar
andym
I read it somewhere on this forum. Also, texcan says his '80 F-100 is 5.5 x 5. One thing about Ford - they aren't consistent.
Old Mar 27, 2007 | 12:51 PM
texcan's Avatar
texcan
Nope, mine has never been changed and they are 5X5.5 patern. When I bought the rims for it, the guy at the place were i got them said "some f100 had the smaller bolt patern and some had the bigger patern, So I'll have to see the truck to price it" He knew about some having the bigger bolt patern. And I know the guy we bought the truck from (I'm the second owner) and he wouldn't have changed it for sure.
Old Mar 27, 2007 | 08:39 PM
wildjon300ci's Avatar
wildjon300ci
Here's what it is...the non-power brake trucks got the 5.5X5 pattern and the power brake trucks got the small pattern. No idea why, but every source I've found/junkyards prove/say the same thing.
