How can you tell if 1st gear is a granny gear?
The easy way to tell, is to put it in first, let the clutch out, climb out of the truck, take a leak and when your done, the truck shouldn't have traveled more an a few inches.
Not really, but that's the idea. In my granny trannys, first gear tached out at about 15mph.
Originally Posted by Big John Hance
On the shifter it says 1, 2, 3, OD. Does that mean 1st is a granny gear?
If you had a granny gear, it would be non-synchronized and you'd take off from a stop in 2nd. You either have a Clark or SROD model 4 speed tranny. A trans with a granny gear is either a T-18 or an NP435.
Thank you very much. I didn't think it had the granny gear since it has OD. I don't think my speedometer is terribly accurate, but 1st gear tops at around 20-25 mph.
I had an 83 F-150 4x4 with a 300-6 and an NP435 trans with granny 1st. I used to live near this unpaved hill that had an 8% grade that was about 1/4 mile from the bottom to the top. It was a huge hill. I could throw the truck in 4-low, trans in granny low, and walk down the hill and wait, wait, wait, for it to come to me. I don't think it even went over 2 mph max going downhill.
1989 ford f150 xlt lariat manual trans
I have 1989. F150 xlt lariat with 4 speed transmission how do i know if i have granny gear when i put in first it goes slow but when i shift to 2nd it revs high as if i skipped a gear as if i through it back in 1st
I believe that anything from 1987 and later should either have a 5 speed or a 4 speed granny. Everything I've seen seems to show they discontinued the 4 speed overdrive transmissions before the 1987 model year.
f100jim
10-25-2007 04:57 PM
BigJake86
11-16-2001 05:46 PM
