- Bad compression test on '85 F-150
- 1985 Ford Tachometer - what is the difference
- Difference between 1985 for tachometers
- Weather Stripping Door Support Rust Repair
- 3 Speed On the Tree Rebuilder Source
- Front swaybar
- Good cam choice for 460
- Will a 302 5.0 H.0 Fit?
- Axle wrap, wheel hop issue
- Longshot door lock question
- Rubber power steering hose pinhole
- Tailgate handle
- 1983 Push Bumper needed
- Power windows added.
- more starter problems
- Donut gasket replacement
- Hi guys
- Duraspark 2 Conversion Ignition Problems
- DSII conversion or replace engine?
- Intermittent wipers?
- Bench seat
- restoring 85 f150
- 1985 f150 relay under dash question
- Speedometer fix
- Wipers not working
- Looking for Mating Electrical Connectors...
- What Carter 1 barrel carb is this?
- Need Timing Help 351w
- Canadian Wire Color Code vs. U.S.
- '86 F150 Relay Question
