- brake lines - hoses?
- 8.8 rear axle bearing help?
- 5 speed in 84 F150?
- Warped Rotors - E150
- Rear wheel arch rot
- SLICKNESS !!!!!!!!
- Anyone interested in a 302 efi swap?
- electric fuel pump
- Dual Exhaust On 300 Six
- sidegapped plugs & mpg
- Side-gapped plugs
- MSD 6A BOX
- Code 41 - HEGO
- 83 fuel tanks
- MPG Success--at least some...
- setting plug gaps after installing an MSD 6A igntion...
- Engine Trouble
- Flairside Fenders????
- timing 300 inline 6
- Installing one-ton axles on a 1985 F-250 4x4 twin traction beam front end
- 1983 351W engine problems
- carb problem?
- Radiator explosion
- OK, now that the tranny is sort of fixed, how do I change the oil pan gasket?
- Tranny for an 84 300 I-6
- Replaced Mazda 5sp w/ T-18 4sp. Piece O' Cake
- Off idle "flutter" and rough idle with I-6
- bell housing for 1983 460
- no spark 82 351w cal.
- Aftermarket AC?
