- EGR Error code question
- Broken Turn Signal Lever
- additions to F150
- "F150 4.9 Auto: Change (3.08 to 3.55)"
- 86 F150 parts / advice ??
- Transmission temperature
- Oil drain plug titghtening specs
- Ford 9"
- 460 Ign Wiring help
- Help!!!
- Read fault codes, need advice
- New Carb Or not
- 1980 F-150,4x4,are frames available?
- 1986 F-150 8cyl. 302
- 4.9L I6 300 vs. 5.0L V8 302
- Emergency Brake
- Truck bouncing when giving gas
- 302,C-6, 3.08 rear
- Fuel Economy and Downshifting
- differential identification
- Transmission Ratios
- E4OD - sudden firm shift 1st to 2nd
- Waterpump change
- Running Poorly
- a/c compressor
- Roller cam installation
- More A/C Problems
- Belt or Bearing Chirp?
- Part beside Coil
- Tranny swap
