- Bench seat slider connector spring?
- Flex a lite or clutch fan or electric fan
- I6 4.9 intake to exhaust manifold studs
- 1985 F150 5.0 efi miss issue
- Automatic to 5 Speed Conversion
- 86 4 spd manual trans issues
- 351w build up
- My first post: no oil at #1 and #3 lifters / rockers 134,000 miles
- Flareside tailgate and bed rails are done!
- No Fuel
- Gave up on coil resistive wire
- '83 inline six idle issue & correlation to exhaust leak
- Reverse/Back-Up Lights.
- Happy New Years FTE !!!
- Rear seatbelts in crew cab.
- Srod shifter saddle replacement
- Factory fog lights
- BW 1345 Transfer Case Rebuild
- easier-running motor-trans for 86 F250 351
- 1984 F150 Kickdown lever problem
- Flareside bed rails partly done
- Truck won't run
- 86 f150 302 carburated - runs good but has periods when it won't start
- 6.9 guys help explain engine viberation pls
- Interesting idea...
- What exactly do I have?
- correct rpm at highway speeds
- 86 F250 clutch pedal bushings
- Radiator Hose Nick
- Dumb radiator question
