zf 5 ??
Old Jul 19, 2008 | 10:06 PM
a711112a's Avatar
a711112a
zf 5 ??
i have a 89 f 350 with a zf5 trans. will any powerstroke engines fit it ?
Old Jul 20, 2008 | 07:06 AM
Dave Sponaugle's Avatar
Dave Sponaugle
What engine is in your 89?
Old Jul 20, 2008 | 09:16 AM
a711112a's Avatar
a711112a
a blown 7.3 idi
Old Jul 20, 2008 | 12:27 PM
David85's Avatar
David85
The starter ring is different on the powerstroke so you will need the starter ring from your current engine to make it bolt up, but the bolt pattern should work. Converting to a powerstroke is not a simple task though. You would probably need the complete donor truck to get it right. I would sooner look for a used IDI....
Old Jul 20, 2008 | 01:26 PM
a711112a's Avatar
a711112a
so would i
but i found a engine they said would work for 1400$ at the junk yard not sure if it is a power stroke or idi will See tomorrow thanks for the help
Old Jul 20, 2008 | 02:10 PM
Dave Sponaugle
The thing you have to consider is the IDI is a mechanical engine.
The Power Stroke is a computer controlled engine.
On the IDI you have a cable going to the injection pump, a mechanical connection from the throttle to the IP.
On a Power Stroke the throttle is electronic and linked to the computer which tells the injectors how much fuel to inject.
Bolting the engine in is the big part of an IDI to IDI swap.
Bolting the engine in is only a very small part of an IDI to Power Stroke swap.
Old Jul 20, 2008 | 05:13 PM
David85's Avatar
David85
Either way, it seems unlikely that a wrecking yard would let a running powerstroke go for only $1400. That sounds like a price for an IDI to me.
Old Jul 20, 2008 | 05:21 PM
goodB0Y's Avatar
goodB0Y
I'll second what david said...:-)
Old Jul 21, 2008 | 11:01 AM
Pele's Avatar
Pele
HOLY *****!
The scrapyard I visit lets engine blocks go for $200 a pop. Doesn't matter what kind of engine it is, engine with heads... $200 flat.
Time to go looking for IDI's...
Old Jul 21, 2008 | 08:53 PM
a711112a's Avatar
a711112a
it was a idi
going to be busy the next couple days
guys! thanks for the input
Old Jul 21, 2008 | 10:44 PM
David85's Avatar
David85
Good luck to ya buddy!
Old Jul 21, 2008 | 11:03 PM
Dave Sponaugle
Pele how far are you from Brandywine Maryland?
There used to be tons of truck yards over there, they had everything you could possibly want for almost anything.
Old Jul 22, 2008 | 07:15 AM
Pele's Avatar
Pele
At an arm and a leg for the cost...
I stay away from Brandywine. They wanted $75 for a tail light on a 1986 Toyota Camry. $150 for a Distributor on a 1985 Mazda... And this was a few years ago. I dunno what the price has gone up to now.
Old Jul 22, 2008 | 10:05 PM
Dave Sponaugle
I lived in Glen Burnie Md. in the early 70's.
They were reasonable back then.
But I was shopping for class 8 truck parts in those days.
XBAJBUSX
23
Oct 22, 2014 06:43 PM
2xford
Sep 22, 2011 09:40 PM
plowguy1225
Apr 18, 2011 04:55 AM
rmalottwtes30
Jun 16, 2009 07:10 PM
NoMo
Jan 29, 2002 12:43 PM
