Bad IP Symptoms
Old Jul 20, 2008 | 03:14 PM
rmalottwtes30's Avatar
rmalottwtes30
Bad IP Symptoms
What are the symptoms of a bad or going bad IP?
Recently my IP seems to be making a lot of chatter noise, thats my guess is its the IP making the noise or what else could it be? Help would be appreciated because I plan on making it the daily driver soon....After I rebuild the transmission...
Old Jul 21, 2008 | 04:54 AM
PLC7.3's Avatar
PLC7.3
How does it run/idle any problems there....... have you checked the bolts that attach the IP to the gear behind the oil fill tube......
Old Jul 21, 2008 | 05:57 PM
rmalottwtes30
its running real good but the chatter is starting to worry me...Im not sure if its been there but I just started paying attention to it and wasnt sure if its just normal or not...When you mean check the bolts behind the IP gear are you meaning to make sure there tight?
Old Jul 21, 2008 | 10:47 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I would check both the mounting bolts and the drive gear bolts.
If my IP makes any noise, I can't hear it over the motor noise.
Old Jul 22, 2008 | 08:19 AM
Dieselamour's Avatar
Dieselamour
Could it be the IP gear noise and a worn IP shaft bushing?
Old Jul 25, 2008 | 05:18 PM
rmalottwtes30
I checked all the bolts there all tight. I used a auto stethoscope and put it up to the IP and it has a steady diesel sound.. I put it up to the lines going from the IP to the injectors and they sound bad, I don't know if that's suppose to sound like it or not, Its a high pitched gear to gear sound on the line from the IP to the injectors....
Old Aug 2, 2008 | 07:37 PM
rmalottwtes30
How do you check to see if the shaft is worn? I just don't like the noise because I never heard it before well being that loud.
Old Aug 2, 2008 | 09:02 PM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
The high pitched noise is probably the gear train to the ip that you are picking up in the fuel lines. I would take the belts loose and idle it to get all the other noise out of the way and isolate the problem. It could be a bad bearing in one of the pullys or vacuum pump,alt,ect. Like the others posted, Do you have any running issues with it? Also, If you are in a garage or shop, Pull it outside to help reduce all the excess running noise from the truck to help better diagnose it.
jmuenchow
Sep 5, 2016 02:58 PM
Kendrick
Apr 26, 2015 12:23 PM
shelby1965367
Mar 29, 2015 07:50 PM
Onus
18
Oct 4, 2012 07:39 PM
altruego
Mar 2, 2011 04:05 PM
