- miss at idle
- non-adjustable rocker shaft questions
- 360/390 difference
- 360 stock carb choke setup
- Great find
- Lifter Question
- should I re-prime oil pump.
- cylinder head ID
- Stupid camshaft decisions
- Balancer
- Fe Mileage Poll
- 352 Questions
- 360 Rebuild advice needed
- c80e 6080-h heads
- 428 trucks
- intakes
- anyone port the rpm intake?
- Help tuning Holley on 390...
- Well I got the New Rollerized C6 in the Truck today!!
- Vacuum
- firering order
- Arrgh!! Header Gaskets!
- Do you need a block?
- Looking to replace 390
- oil in cylinders
- Valve/spring deposits
- problems swapping 390 to 330
- Cam ID
- Well another Cam change for the 433 Cobra!!
- Best lift points on a 360?
