Cam ID
Old Sep 7, 2005 | 12:28 PM
tall69's Avatar
tall69
Cam ID
Can anyone help ID this camshaft (see link below)? It's got .500 lift on both lobes (with 1.73 rocker ratio). I hoping it's a NOS C8AX-6250-C cam. Did only 427 cams get the grooves in the number 2 and 4 bearing journals? I'm inclduing the link because it has photo's of the cam.
http://www.network54.com/Forum/messa...eid=1126061045
Thanks.
Old Sep 7, 2005 | 12:35 PM
fordeverpower's Avatar
fordeverpower
um can you list all numbers and letters, colors and where they are at?
Old Sep 7, 2005 | 12:44 PM
tall69's Avatar
tall69
Markings
The attached post shows two pictures. One of the end journal with what looks like a 144MAZM maybe. The other is between the last lobe and journal. It's sprayed blue with some kind of date casting (not readable) I believe. Those are the only two indicators as far as I can tell.
Old Sep 7, 2005 | 12:53 PM
fordeverpower
I question weather it is NOS. its hard to say what it is there are several old cams with 500 lift and a couple with grooved 2 and 4 journals. The cam you are hoping it being, does not have grooved journals.
Old Sep 7, 2005 | 01:42 PM
tall69's Avatar
tall69
Is it a 427 cam then?
It must be a 427 cam (because of the grooved bearings). Can one tell if a cam is intended to be used with hydraulic or solid lifters by appearance?
Old Sep 7, 2005 | 01:51 PM
fordeverpower
I have a melling mtf-4 in my garage with grooved 2 and 4th journal. .484/.510 lift.
Old Sep 7, 2005 | 02:26 PM
Bear 45/70's Avatar
Bear 45/70
427 63/67 Hydraulic 282/296 with 58 overlap. I have the rest of the specs if you want them. This cam is the next step up from the 390GT/428CJ cam and with no other changes will give you about 15 hp over the CJ cam.
Old Sep 7, 2005 | 02:42 PM
fordeverpower
bear, he is not asking for c8ax-6250-c specs. He wants help with the identification of the cam in the pictures.
we know:
its has grooved journals, blue paint on the end, and 144mazm stamped on it. I am at a stand still without any more info. There should be some letters stamped on the cam bewteen lobes or something.
Old Sep 7, 2005 | 03:10 PM
tall69's Avatar
tall69
I'll check it over again tonight.
Old Sep 7, 2005 | 06:15 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
All the listings I have for the C8AX-6250-C cam state it has oil grooves on the 2 & 4 journals. From the looks of your pics I can kind of see a "C" but really hard to tell otherwise. Maybe try a lupe or mag glass for a better look. The two other Ford cams that have .500 lift are the C3AZ-AA and the C4AE-B and both have grooved journals but are mech lifter cams. Maybe try Dave Shoe, Hawkrod or Royce P if no other luck. I'm sure Royce P would know.....G.
Old Sep 7, 2005 | 07:24 PM
Bear 45/70's Avatar
Bear 45/70
The C8AX-C cam is marked "C8AX-C" on the end of the last journal, at least according to the Ford Muscle Parts Book. The C3AZ-AA cam is marked with an upside down A, then a BA between the last lobe and the last journal. The C4AE-B cam is marked with an upside down A and then an M, between the dist gear and the first journal. The last two cams are mechanical sticks. Actually there is a third Ford cam with .500 lift. A C3AZ-D marked with an upside down A and a B, between the last lobe and the last journal.
Old Sep 7, 2005 | 09:20 PM
tall69's Avatar
tall69
Alright. I checked it thoroughly again tonight. There are a few more indicators.
There is a C2 and D2 by the number 3 journal 180 degrees opposite from one another. On the other side of the journal, there is what appears to be a CW0 or maybe CMO.
Between the last lobe and number 5 journal there are several indicators. The first is a CWC (or CW8) with a 23 or 28 casting tag below it. 180 degrees from that is a SF 63 with a 6 or G enbossed in a casting tag below it.
Again, the number 2 and 4 journals have grooves in them. The lobe base circle is 1.510", the high point of the lobe is 1.800". This yields .290", or .5017 with a 1.73 rocker ratio.
That's about all I got.
Old Sep 7, 2005 | 09:46 PM
Bear 45/70's Avatar
Bear 45/70
Can't help ya man. The numbers given match nothing in my book. The .290 lobe lift matches the numbers for the 427 cams that have .500 valve lift.
Old Sep 8, 2005 | 06:53 AM
russrobbins's Avatar
russrobbins
The C8AX-C,according to the info in the books,is supposed to have the part # on the end of the last journal.This really doesn't mean a lot to me because I have removed many cams from non rebuilt FE motors and very few I have been able to ID from the current published info.I purchased a C8AX-c new in 1970 from Ford for a 1965 galaxy ragtop.I remember reading what came with the cam and I believe all it was a spec sheet glued to the box it came in.The only thing I'm sure of was the .500 lift printed on the sheet.
Old Sep 8, 2005 | 07:59 AM
tall69's Avatar
tall69
Do most original cams have the fomoco stamp somewhere on the cam? This one does not. I may have to degree the cam to figure out exactly what it is.
